Laptop is losing it's gusto, thus I am looking to upgrade and have decided to take it upon myself to make my first ever personal build. I have made a lot of headway in researching all the necessary components and have made a possible setup list with options, which is why I am seeking advice to make the final decisions. What I am looking to accomplish is an above average personal home setup for everyday use/some gaming/some 3D modeling. (not high end AutoCAD modeling, just SketchUp I'd say). Budget around $1,000 to $1,500. Looking to make this happen by the new year, personal present to myself. And yes I will be buying a monitor. So please take a look at the selection below and let me know what you think. PS: Definately need help with motherboard selection.
CPU: Intel Core i7-4770K Haswell 3.5GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116901
Note: I have no knowledge of overclocking but am getting the k version in case I am ever intrigued. Also I believe this version better supports multiple displays.
MOBO: This I cannot decide on and need the most help with. I do want a Z87 chip-set and an ATX model however, so I am thinking the following as options. (wireless would be nice but I can add that on as an extra).
-ASRock Z87 Extreme4 LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=13-157-369&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=2#scrollFullInfo
-ASUS Z87-PLUS LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=13-131-980&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
-ASUS Z87-PRO LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131979&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
-ASUS MAXIMUS VI HERO LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=13-131-989&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
-MSI Z87 MPOWER LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Extreme OC Flagship High Performance Triple CFX/ SLI Platform Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=13-130-691&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
(It has been noted in multiple reviews on this board that the "Killer" Ethernet chip is garbage)
-GIGABYTE GA-Z87X-UD3H LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=13-128-592&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
Lots of options for the mobo I know but I just can't decide. I don't plan on having any more than two graphics card though, if that, which is next and brings up a question.
GPU: A couple options here but I know I want Crossfire/SLI ready, 1 or 2 GB memory on board, OpenGL 1.5 or higher (for Google SketchUp modeling), and something powerful for gaming.
-AMD Radeon HD 7870
-Geforce GTX 660
-NVIDIA GTX 760
Note: I know there are big differences between workstation and gaming computer components and I stated I'd be doing some 3D modeling, but i think there shouldn't be a big problem here. However, if i wanted the best of both worlds, is it possible to join one gaming GPU and one 3D modeling GPU in crossfire/SLI layout and achieve this or is that not possible?
Hard Drive: I want one 120Gb SSD and one 1TB or so HDD. The SDD for the OS.
-SAMSUNG 840 EVO MZ-7TE120BW 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147247
-WD BLACK SERIES WD1003FZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236625
Memory: (RAM) 16 GB low latency DDR3
Note: Will be determined based on compatibility with mobo. Any good brand name suggestions are welcome.
PSU: Would like this to be completely modular and have extra power for growth. Want to run at the 50% mark for efficiency, thus looking at 850W units.
-KINGWIN Lazer LZ-850 850W Modular 80 PLUS BRONZE Certified Active PFC W/ 3-Way LED Switch and Universal Modular Connector Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121067
Case: I like the first the best but am worried that it will not get enough front ventilation.
-BitFenix Shinobi Window Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345010
-Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case, come with Five Fans, window side panel, top HDD dock
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
-White Enermax Hoplite ST Mid Tower Computer Case, Integrated 3-Step Fan Speed Controller, Front USB 3.0, w/ Dual 120mm Fans, P/N: ECA3261-W (Apparently out of stock on newegg but could get elsewhere)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811124154
Optical drive: CD/DVD/RW
-ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
+Wireless adapter depending on mobo.
-ASUS PCE-N53 Dual-Band Wireless-N600 Adapter IEEE 802.11a/b/g/n PCI Express Up to 300Mbps downlink+300Mbps uplink Wireless Data Rates WPA2
http://www.newegg.com/Product/Product.aspx?Item=N82E16833320113
+Monitor - 1920x1080 HD, possibly Samsung.
Also, I'm thinking widows Vista as I may have an extra disk and key. 64 bit. I'm iffy about widows 8...
Other Info- I am located in NY (not the city), I don't have a preference besides Intel CPU, and I haven't gamed on a PC in a long time so i have no basis for requirements.
Thank you for anyone who is willing to take the time and help this first timer out.
I really appreciate it
-AMD Radeon HD 7870
-Geforce GTX 660
-NVIDIA GTX 760
