Hi all,
I am helping a friend build a computer, but I'm having problems with the boot up process. I have built several computers successfully, but this one's giving me trouble.
Here's the problem:
When I power it on, everything lights up and works normally. However, nothing shows up on the screen, and the keyboard lights do not come on. At this point, we didn't wait more than 30 seconds, till we shut it off.
We tried the RAM individually, in each socket, as well as the other stuff on the troubleshooting check list.
After about an hour, we decided to take everything apart and do it again. The motherboard seating is in the right place too. I popped out the motherboard battery and put it back in after a minute.
I am running it barebones right now, just the CPU, HSF plugged in, and in the back, just the onboard video and a keyboard.
We were just about to give up when I left it on for about 2-3 minutes and magically the screen lit up and said something about CMOS error, and went into the Loading Operating System Screen. Since there was no HD connected, it gave me a boot error.
I tried again, same 3 minute delay, but this time it skipped the POST completely and went straight to the Loading Operating System screen.
Any ideas what could be the problem with the 3 minute boot up time and POST skipping?
Here are the specs below, but keep in mind, it's just barebones right now. PSU, Mobo, CPU/HSF, VGA and mouse in rear.
Thank you
By the way, I'm planning to take my computer to his house on Monday, and testing out my identical Power Supply, and also test out his sticks of RAM. What other things would you guys recommend?
Everything purchased brand new delivered today from Newegg.
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
GIGABYTE GV-R585OC-1GD Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5"
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
GIGABYTE GA-880GA-UD3H AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX4GX3M2A1600C9
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
Here's the problem:
Thank you
