I just got an intel core i3 10100 and a B460 Aorus Pro AC motherboard because I wanted to upgrade from my old motherboard and processor so I could run games like call of duty at a higher frame rate. I made sure I plugged in everything correctly all fans are running even gpu fans when I turn the pc on but it just won’t post. Please help. I will respond to any other questions you may have about the build in a reasonable time frame.
Old System Specs:
Cpu: Intel Core i7-3770
Motherboard: ASRock Z77 Extreme 4
Ram: Some miscellaneous ddr3 ram that I had from older pc
Hd: WD Blue 500gb hard drive
Gpu: Nvidia GeForce GTX 660ti
Psu: Insignia NS-PCW5508 (550W)
Case: Thermaltake V200
Os: windows 10
New Specs:
Cpu: Intel Core i3 10100 (10th gen)
Motherboard: B460 Aorus Pro AC
Ram:V-Color Skywalker series DDR4 (2x8gb) in 2nd and 4th slot which is where the motherboard says to put them in first
Hd: WD Blue 500gb hard drive (same as previous build)
Gpu: Nvidia GeForce GTX 660ti (same as previous build)
Psu: Insignia NS-PCW5508 (550W) (same as previous build)
Case: Thermaltake V200 (same as previous build)
Os: Windows 10
