(Specs)
- Integrated Sound Card
- 1TB Seagate 3.5" 7200rpm SATA 6Gb/s HDD PN ST1000DM003
- AMD AM3+ FX-8350 Eight Core 4.0GHz 8MB Cache 125W Black Edition CPU
- DVD Writer ASUS 24x DRW-24D5MT Black OEM
- Gigabyte AM3+ ATX GA-970A-D3P Motherboard
- Zalman CNPS90F CPU Heatsink and Fan
- 8GB DDR3 Crucial CT102464BA160B (1x8G) 1600MHz Ram Module
- 600 Watt Coolermaster B600 Power Supply PN RS-600-ACAB-B1
- Deepcool ATX Tesseract SW Case Black with Window (No PSU)
- 92mm Zalman ZM-SF2 Shark’s Fin Blade Silent Fan
- Microsoft Windows 10 Home 64bit OEM DVD PN KW9-00139
- MSI GTX950 2GB Gaming PCIe Video Card PN GTX950 Gaming 2G
- 120GB Kingston 2.5" SSDNow UV400 SATA 6Gb/s SSD Drive PN SUV400S37/120G
Hello all, I'm seeking advice as to why my monitors say no signal with a new CPU fan. Listed above is the zalman heat sink/fan, which I am replacing with what I believe is the stock fan which was set aside. Since the zalman was installed on build from the store.
Any who, last night I replaced my psu with a new one. Focus plus 80 gold 650fx fully modular. After installation everything worked fine. I then replaced the CPU fan with a cooler master (which has the pre thermal paste square) but on start up my monitors give me "no signal" I've taken everything out and reseated, twice. I never took out the CPU, I removed the old thermal paste from the zalman.
The zalman fan works fine when i place it back in. I've redone my ram, gpu, pretty much all the common things, touched the two cmos with a screw driver as said, removed the cmos battery, replaced it. Still nothing.
Thank you for any reply.
