Hi. After thinking about it and because temps are getting higher and higher here where I live, I have decided to get rid of my "modded" CPU heatsink ( a 70 mm Cooler Master on which I put another Cooler Master's i117 XDream's 90 mm fan ), and put abetter one (I want a 95W dissipation even If the max TDP of the Athlon on which It'll be mounted is 65W), so I have choosen the NOX HUMMER H100 85 mm from this site:
http://www.appinformatica.com/ventiladores-nox-ventilador-hummer-h.100-85mm-26.4dba-negro.php
Although it is clearly stated there that it is compatible with Athlon processors...
...and so with the Socket A platform, I want to know what is your experience installing this NOX product in this type of socket.
I have noticed that the metal pin\lever that keeps the HS in place seems to be longer in the NOX's HS, althoug the part that attach it to the bracket has a mobile part. Should it be modified or will it work like that?.
Thanks in anticipation!.
Intel Socket 1156 /1 155 / 1150 / 775
- Core i5 / i3
- Core 2
- Pentium
-AMD Socket FM2/FM1 / AM3+ / AM3 / AM2+ / AM2
- FX - series
- A - series
- Phenom II X4 / X3 / X2
- Phenom X4 / X3
- Athlon II X4 / X3 / X2
- Athlon X2
- Athlon
- Sempron
