Hello, I have CM Hyper TX3.
There is a weird problem. Some kind of sound is coming from fan when its RPM is in between 1600-2300. Its not vibrating as far as I can tell. Temps are good, so its not some other problem.
Sound I can describe is some wire hitting blade, but there isn't one. So I think the fan is dying.
If the problem can be resolved its good, else I think I'll replace the fan, so I'm looking for options.
I know there is Blade Master 92mm, but its expensive.(1250/- INR for fan, 1550/- INR for new Hyper TX3).
I'm looking at this fan,
Vantec Thermoflow 92mm Double Ball BearingTemperature Controlled Case Fan - Model TF9225L
http://www.newegg.com/global/in/Product/Product.aspx?Item=N82E16811999617
Its cheap and they ship to India. My question is, will that work perfectly? If not, I would like some alternatives.
Thank you.
Thank you.
