I'm looking to build a gaming rig. It will be my first in about 6 years. I found this template on another thread, so I filled it out already.
Approximate Purchase Date: sometime between 7.18.2011 today and 8.15.2011 a month from now
Budget Range: $1300 - $1500 (before any Mail in Rebates)
System Usage from Most to Least Important: Gaming - I'm hoping to max most mainstream First Person Shooters specs for at least 18 months.
Parts Not Required: peripherals (keyboard, mouse, external hard drives, monitor, printer)
Preferred Website(s) for Parts: newegg, amazon. I'm open to Tiger Direct and ncix.com, but I've never used them.
Country of Origin: no idea what this is for. I live in the USA.
Parts Preferences: part by part basis (see listing below)
Overclocking: Yes. I've never done it, so experimental at first, then hard core as I figure it out.
SLI or Crossfire: Yes (but not right away, or I'll go over budget
. I'll probably get another GTX 570 in about 3-4 months.
Monitor Resolution: 1920x1080 or 1920x1200 (not sure which, but under 2000 for width and height)
Additional Comments: I'm open for suggestions, but I'm also open for an education. I'd love to know WHY you're recommending apart, or WHY you think a part won't work.
Here's my parts list. I was hoping that you guys could take a look at it and let me know if I've hit the mark.
CPU - i5 2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
MOTHERBOARD - ASUS P8P67 PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131703
ASUS P8P67 PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
OR (make suggestions)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
ASUS P8Z68-V PRO LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
RAM - G. SKILL Sniper 8GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
GPU - EVGA GTX 570
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
EVGA SuperClocked 012-P3-1572-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support
PSU - CORSAIR HX850 850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
CASE - Cooler Master HAF 912
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
HARD DRIVE - HITACHI DESKSTAR 1.5TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145520
HITACHI Deskstar 7K3000 HDS723015BLA642 (0F12114) 1.5TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
OPTICAL DRIVE - ASUS DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
EXTRAS
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015
CORSAIR CWCH60 Hydro Series H60 High Performance Liquid CPU Cooler
EXTRAS
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Noctua NH-D14 120mm & 140mm SSO CPU Cooler
solid state drive
-none so far-
A few questions, if anyone can lend a thought...
1) Are these parts actually compatible? I'm hoping I didn't overlook anything obvious. I know that the CPU Socket on the CPU must match that on the motherboard, for instance. I also know that the Motherboard Memory pin count needs to match the RAM pin count. But then I see a Motherboard North Bridge and I'm not sure how that relates to other components. Or I see Memory standard on the Motherboard and I'm not sure how that relates to the RAM Speed.
2) Will any of these parts cause significant bottlenecks (ie will the Mobo prevent the CPU from reaching its full potential?). I know that parts can be compatible, but still not be optimal for each other.
3) I'm Planning to do some overclocking (CPU, GPU, RAM). When prices come down, I'm planning to do some SLI with the GTX 570. Will these parts support that (so far, I've never overclocked. Still have to read about it)? Will the PSU support SLI and overclocking?
4) Since I plan on doing some SLI, would I be better off with a Radeon 6950 in Crossfire instead? If so, would a Radeon 6950 be compatible with the rest of the parts? Note: I have a 22-inch screen and will not be going over 1920x1200 and will not be using multiple screens (I heard Radeon takes the lead in screens over 2000 or multiple screen layouts).
5) I gave very little thought to the Case/Tower, the Optical drive, and the hard drive. I basically just picked out cheap stuff. Does anyone have any better suggestions?
6) Regarding the CPU fan and the Cooler, someone from work suggested them. I don't have any idea how the cooler works yet. Is this worth looking into (or possibly even necessary to look into - I don't know what kind of overheating to anticipate. I still have to read up on overclocking and SLI/Crossfire).
I'm even more interested in an education than in just suggestions. If you recommend a part, I'm very eager to know why, if possible. But I'll take what I can get.
I know that I'm terribly wordy. Sorry about that. I know I've said a lot and asked a lot. Any insights or suggestions are appreciated.
Looking forward to your thoughts, and thanks in advance.
. I'll probably get another GTX 570 in about 3-4 months.Monitor Resolution: 1920x1080 or 1920x1200 (not sure which, but under 2000 for width and height)
CPU - i5 2500K
GPU - EVGA GTX 570
EXTRAS
EXTRAS
solid state drive
-none so far-
