New mini itx build with questions about 4790k temps
Ardems
50
So I just finished building my new mini itx machine and everything seems to be running as I would expect it to. Games run fine, benchmarks are showing similar results to builds with the same setup. Now I'm just left with one question, are my temperatures good. I decided to go with an H100i due to the lack of airflow and think it's doing fine.
Here are my temps and voltage/clock information. I know that the 1.245v on the CPU voltage is a little high, but that's what ASUS chose for me and I have no idea how to navigate this new BIOS to change it. I'm not familiar with the way that they have it setup as opposed to my older motherbaord, someone told me to use the adaptive settings for voltage, but I couldn't figure it out and didn't want to screw up my processor.
Anyway, I don't plan on getting it any higher than the stock 4.4 ghz turbo that it came with and those temps I posted for from running fire strike on 3dmark 3 times and a few hours of playing WoW. I just plan on using the PC for games and school work, so I won't be doing anything very stressful, but my hottest core maxed at 76 C while running prime95 for 2 hours, which I know isn't good for Haswell but I just ran it to see if I stayed below 80 and didn't encounter any errors.
Edit: My ambient temps are ~21C
