Question New monitor not detecting
Jul 1, 2023
Hello There, I recently purchased LG ultragear 24GN65R, but when I connect it to my pc, it says "no signal detected". I tried both Display port and HDMI port, I even tried another HDMI cable to see if cable is damaged, but none of them worked. My gpu is 1050 ti. My old monitor works perfectly but it is connected via Dvi port. Perhaps problem is my gpu ports? I tried to connect my old monitor with HDMI instead of DVi and it didn't work.
Any ideas?
Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard?
You might want to hook the assumed faulty panel, to another display output source, that's know to be working...like a laptop or a desktop at our friend's/neighbor's home.
