Hi guys,
I have recently upgraded my setup and bought myself the Gigabyte Aorus FI27Q and I am now struggling with a few issues that I can't seem to get rid of. Previously, I was already running a 2 screen setup with a BenQ XL2411 144hz monitor as my main monitor and an older Samsung monitor as the secondary screen. I used to have my taskbar and explorer/discord windows on my secondary monitor and run Media/Browser and Games on the BenQ.
After buying the Aorus FI27Q, I was planning on using the FI27Q as my main monitor for games and media and use the BenQ as secondary monitor. The first issue I now have, is that the FI27Q always seems to have a slight color tint, I am currently using the "Aorus" picture preset and depending on the Color Preset, I notice either a slight yellow or blue tint of the screen. When I compare a website or program on my two monitors, I can see a "proper" white on the BenQ while the Aourus is always kinda tinted. Do you have any suggestions to fix that?
The second issue is quite annoying as well. I set up the taskbar on the BenQ and chose the "Lock Taskbar" option. I also have a couple of desktop shortcuts on there. The issue now appears, when my monitors go into standby/shut off because I am AFK. When I return and move my mouse, I can see that no shortcuts are visible on the BenQ and they take a couple of seconds to load in. Additionally, all windows I had opened on the BenQ are now shown on the Aorus. The taskbar also "switched monitors" and is no longer visible on the BenQ but on the Aours. To me, this kinda looks like my computer is losing connection to the BenQ and therefore moves everything to the Aorus as if it was the only monitor connected. Is that possible? Is there any way to prevent that "short term loss of connection" for the BenQ? This never happened when I was running my old 2 screen setup with the BenQ and the Samsung.
I hope that I could somewhat clearly describe my issues and that one of you is able to help me out.
Cheers and thanks
Cheers and thanks
