Hey guys!
I just picked up a new motherboard, some RAM, and a new vid card and am having some issues with my computer turning itself off.
Heres some specs off the top of my head:
Intel Core 2 Quad Q6600 - stock speed
EVGA 790i SLI FTW mobo - just got it
4 GB Patriot Viper DDR3 RAM - just got it
EVGA Nvidia GTX 260 Superclocked video card - just got it
Ultra X3 1000W power supply
Various hard drives and DVD drives
Anyway, I connected everything, made sure everything was seated correctly, powered on my computer and it stayed on for a few minutes and then shut off without warning like the power had been cut. It lasts for random amounts of time before it dies on me, but it never lasts for more than 30 minutes. I have noticed that once it turns off the first time, it tends to turn off quicker than before (maybe heat related?).
I have done some research and most say its either my power supply or could be a failing device. I had some G Skill DDR3 RAM before the Patriot RAM and still had the same issue so I don't think thats it. I've only had my PSU for 2 months so I don't think thats it either, though I guess it still could be?
My first thought was heat, but the red light on the new board (indicating heat problems) never comes on when the system powers off. I even picked up an Arctic Freezer 7 Pro, replaced the thermal compound with some Arctic Silver 5, and made sure all 4 of the pins were secure.
Also, SpeedFan reads my cpu temp idling at around 35C and the video card temp is well within normal ranges so I don't think it is heat, though my BIOS has no idea what my temps are. They bounce around from anywhere between -45C and 60C so I don't know whats up with that.
No matter what I tried, I couldn't get the system to stay on so I swapped out the new stuff with the old. My old set up had two Nvidia 8800s in SLI but now I have the new video card in the old board by itself with old RAM and the same problem happens. The system randomly turns off as if the power had been cut but it stays on for hours before it turns off.
I can't really try a different PSU since the only other one I have does not have the 8 pin connector to fit the new motherboard.
I have a hard drive with a clean install of Vista on it and I still have the same problem, so that rules out any OS problems (I hope)
*** Currently running on all of my old stuff and have been stable for an hour so far, though the point of getting new stuff is to...use it 🙁
All drivers are up to date as well as my BIOS.
Any help would be appreciated. Been working on this for days now and its frustrating.
Thanks!
Thanks!
