Question New pc and need help for gpu
Dec 12, 2019
7
Hello everyone i want to know if this kit is good and if so which gpu should i go for to complete this
CPU : I5-9600K
MOBO: ROG Strix Z390 E Gaming
RAM : DDR4 Sport LT 16GO Ballistix 3200 Mhz CL16
PSU: Corsair CX600 - 600W, 80 PLUS Bronze
RodroX
Notable
Aug 4, 2019
705
206
890
27
Hi, you have a few options (but Im not sure where you live):
Probably something like nvidia GTX 1660 Ti 6GB, GTX 1070 8 GB (if you can find one new), or Radeon RX 580 8GB
Nov 26, 2019
26
All great choices. You're definitely not strapped for power, so if you can get at 1070 new (probably not, unless you want to gamble with used), that would be your best option. Otherwise, the 1660 Ti is the best option.
The Polaris-based RX 580 won't suffice, I'd suggest an RX 590, and even then I'd still take the GTX 1660 Ti.
Dec 12, 2019
7
I live in France all these models can be found here! ty
ok so the 1070 is a bit expensive and i never gamble ahah so i will go with GTX 1660 TI!
Last question will this rig perform well with games like Assassin's creed etc you know games with high graphics
Nov 26, 2019
26
At max settings you'll get about 50 fps on Assassin's Creed Odyssey. You may have to dial back the settings, or you'll have to spend more money on, say, an RTX 2060S or RTX 2070.
Edit - Assuming 1080p of course.
Dec 12, 2019
7
aah ok maybe i can get my hands on one of them during January sales ahah
Nov 26, 2019
26
I found an RX 5700XT on Newegg for $389. You should get this bad boy if you're doing some serious gaming. It'll probably outperform the RTX 2060, but not the RTX 2070 or RTX 2060S. But if you're willing to drop performance slightly, save $70 and get the RX 5700XT (or save $30 from an RTX 2060S)
https://www.newegg.com/asus-radeon-rx-5700-xt-tuf-3-rx5700xt-o8g-gaming/p/N82E16814126346?Item=N82E16814126346 ($30 off)
Dec 12, 2019
7
the Radeon is the way to go then Thank you very much!!
