New Pc build and parts compatability
EStark
Commendable
Mar 15, 2016
6
Hi everyone!
Novice PC builder here, first pc build.
I just wanted to know if these PC parts are is compatible and if I should change anything according to you guys.
Intel core i5 6500 3.20GHz 6th gen (using stock cooler)
Gigabyte GA-H110M-S2 DDR4 Intel 6th Generation Motherboard LGA 1151
Nvidia GTX 750Ti
G.skill 2400 mhz ddr4 ram
Corsair 550 Watt smps
Coolermaster k380 cabinet
I'm not gonna overclock in near future so do I need aftermarket cooler, cpu can be turbo boosted to 3.60GHz?
I've used online sites to look for their compatability they're good to go but it would be great if you guys give confirmation too XD and if you have any suggestions for changes please do tell!
Any help is greatly appreciated! Thank you so much!
Sorry for long post ^_^'
Components on amazon
Intel Core i5 6500 (LGA1151 Socket, 3.20 Ghz Turbo Boost to 3.60 Ghz, 6MB Cache) - 6th Generation Skylake for Intel Z170 Chipset DDR4/DDR3L Technology https://www.amazon.in/dp/B010T6CWI2/ref=cm_sw_r_other_awd_dKH6wb0QG8B63
ZOTAC GeForce GTX 750 Ti 2GB Graphics Card (Black/Orange) https://www.amazon.in/dp/B00IFZ547Q/ref=cm_sw_r_other_awd_9LH6wbKR9WYER
Cooler Master K380 / Window / USB 3.0 https://www.amazon.in/dp/B009AJ8HPW/ref=cm_sw_r_other_awd_EMH6wbHJWEA0C
G.SKILL Ripjaws 4 8GB (2 x 4GB) DDR4 SDRAM 2400Mhz Desktop Memory Module F4-2400C15D-8GRR https://www.amazon.in/dp/B00XNADM8Q/ref=cm_sw_r_other_awd_PLH6wbK3SEP2A
Gigabyte GA-H110M-S2 DDR4 Intel 6th Generation Motherboard LGA 1151/ Intel H110 https://www.amazon.in/dp/B019ZLM7A0/ref=cm_sw_r_other_awd_pTw6wb3BPG4Q4
Corsair VS Series VS550 - 550 Watt SMPS https://www.amazon.in/dp/B00DQ5OB4C/ref=cm_sw_r_other_awd_lLH6wb9HJ82JH
Should all work together. You'll only be able to run your RAM at 2133mhz, but having 2400 won't hurt.
You might find a better value video card than the 750Ti, but overall it looks like a reasonable build.
EDIT: No need for an aftermarket cooler.
