New pc build, i want have parts checked out for compatibility issues.
coronaextra
5
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($119.99 @ Newegg)
Motherboard: Asus M5A97 LE R2.0 ATX AM3+ Motherboard ($75.91 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($86.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: Sapphire Radeon R9 270 2GB Dual-X Video Card ($152.98 @ Newegg)
Case: NZXT Source 210 (White) ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($24.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($102.98 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($32.98 @ Newegg)
Total: $691.79
The actual price on newegg is $684.93 and will have premier shipping.
The board you chose has a poor thermal design . and you need a better and more powerful PSU.
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard ($74.99 @ Micro Center)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1600 Memory ($87.99 @ Newegg)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($39.99 @ Newegg)...
Your power supply is on the edge, of too small.
The video card manufacturers minimum is 500watts.
It can probably handle it, because the recommendation is a little inflated, to take into account crappy power supplies.
That Corsair, is only on the edge of good.
That being said, I use that line of Corsair, and have never had a problem, but I go with the recomendation.
Total: $666.88
That's up to you, if it is not a pain, and all the vendors are reputable.
I would order all at once regardless, as the clock will be ticking on a return to the vendor.
If you wait too long to assemble and test, you will have to go to the manufacturer for a warranty replacement, if something is bad..
