New PC Build; System Fans, Etc. spin for a sec then stop when turned on.. (PC wont run)
mikecara
12
Hello, I recently made a thread similar to this. My current motherboard I used for the build is a Gigabyte GA-Z170X Gaming 7 and the bios needs to be updated for the Core i7 7700k I am wanting to use to be supported and work. So I purchased a Pentium processor that is already Supported with the current downloaded bios. I figured this was the problem because it was suggested by someone on here. But, about 2 hours ago I recieved it and built the PC again with the Pentium Processor but the same thing is happening. I am new to PC building, its my first time. So, I am just confused on why this is happening and what I have to do to fix this ongoing problem??
Could be a thermal problem, remember to use a thermal paste on the chip/fan. They can heat up very quickly if you don't and this sounds like the type of thing that would happen in such a case.
Also try resetting the CMOS.
Specs:
Gigabyte GeForce GTX 1060 Windforce OC 3GB GDDR5 Graphics Card
Intel 7th Gen Intel Core Desktop Processor i7-7700K
(and Intel Pentium G4400)
WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5 Inch Desktop Hard Drive
Cooler Master Hyper 212 EVO RR-212E-20PK-R2 CPU Cooler with 120mm PWM Fan
CORSAIR Vengeance LPX 8GB (2x4GB) DDR4 DRAM 3000MHz C15 Memory Kit - Black
Gigabyte ATX DDR4 Intel LGA 1151 SATA E (6Gbit/s) Motherboards (GA-Z170X-Gaming 7)
Corsair CX Series 550 Watt 80 Plus Bronze Certified Modular Power Supply
Corsair Graphite Series 780T Full Tower PC Case - Black
