New pc build won't boot. Boot device led red.
Jan 13, 2019
21
So i built a new pc from a few spareparts and a few new ones. When i booted it up i first got the dram led red, but reseating the ram and running memok! Fixed that problem. Now when i try to boot it starts up fine but after 10 or so seconds the boot device led lights up a solid red. And i dont get any signal to any of my screens.
What i've tried so far:
Remove the gpu (did nothing)
Use just one stick of ram (nothing)
Remove bios battery (nothing)
Remove everything from the case and run it there (nothing)
Reconnect all the wires from the psu (nothing)
Remove the 4x4 cpu power (the cpu led lit up red on the motherboard)
Remove everything except cpu, cooler, cpu, ram (nothing)
Start with a usb stick (nothing)
I thought that it had to be the cpu or motherboard, but wouldn't the cpu light always light up if it was a cpu problem?
I need some help.
I'll check when i have time. But it's an older case and is missing the original screws (not standoffs, the one you screw into the standoffs) so i had to use some other screws. Could that be a problem?
