New Pc Enough Power/Compatible?
mlp353
64
Hey This is my second pc build i just wanted to build somthing that could play games on high/max 1080 with no problems. I just wanted to know is this enough power? Is everything compatible and should i get a diffrent gpu? THANKS
power supply: CORSAIR CX series CX750 750w
ram: G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
mobo: MSI 970 Gaming AM3+ AMD 970 6 x SATA 6Gb/s USB 3.0 ATX AMD Motherboard
cpu: AMD FX-8320 Vishera 8-Core 3.5GHz (4.0GHz Turbo) Socket AM3+ 125W
cpu cooler: Cooler Master Seidon 120V – Compact All-In-One CPU Liquid Water Cooling System with 120mm Radiator and Fan
hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
Gpu: R9 390x
I just wanted to know is this enough power? A PC with a R9 390 in it needs a good quality 650+W PSU. The CX is not good enough quality to ensure protection of your gtx. Try a Seasonic 650, evga gs 650 or XFX650 instead
You don't have a case. Make sure the GPU will fit. Otherwise it should be fine.
Those parts will work. I'll throw you another option (since your going for 1080p resolutions):
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($176.98 @ NCIX US)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard ($82.98 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($50.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive ($84.99 @ Amazon)
Video Card: MSI Radeon R9 390 8GB Video Card ($329.99 @ Amazon)
Case: Corsair 300R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply ($54.99 @ Newegg)
Total: $830.91
Generated by PCPartPicker 2015-07-08 00:34 EDT-0400
* CPU is plenty and usually perform => the 8320 in gaming.
* Mobo is plenty (even the h97/B85 chipsets will also do well too if you need to curtail the budget a little).
* RAM is good and solid for the $.
* GPU is plenty for 1080p gaming (even 1440p should do well also). The 390 is about the same as the GTX 970, so keep that in mind (and it has been a bit cheaper).
* SSD is something you should consider. It doesn't affect FPS, but will make your load times and snappiness in and around the OS quite nice.
With one exception, the system looks great.
The one exception is the power supply. The Corsair CX power supply has been rated here on Toms as a Tier 3 power supply. They seem to work ok as long as you put a fairly light load one them. But when you start to push them more, many of them start causing power shutdowns, random errors, and just making your gaming life miserable. There are worse power supplies out there. And there are better ones as well. The ranks for power supplies go from Tier 1 to Tier 5. We recommend that people buy a power supply from Tier 1 or Tier 2. These have higher quality parts and are better made. As a result, they handle gaming rigs better. I will link the list I use to check on power supplies that people are looking at buying to see how they are rated. Just remember that your computer needs a steady and constant flow of smooth power to perform at its best. Do not go cheap on the power supply.
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
