[SOLVED] New Pc won’t turn on, no lights no twitchy fans nothing (First Build)
Feb 24, 2022
I don’t know how this happened I was building the pc putting in the fans I turned it on it worked fine so I turned of had dinner came back and now it won’t turn back on. I don’t know if I did something to make it do that but I’ve checked the power supply to see if it works with the paperclip trick and it won’t turn on but It’s weird because its brand new, literally worked fine and then dinner happened. Also every now and then when I try to turn it on I’ll here a click two clicks one that the power button always does and the rare one of the power supply making a click. But then nothing happens anyway. Before dinner when I was working on the pc I had just installed the m.2 and more fans. I unplugged some fans to see if the pc would then turn on because not as much power :/ . I don’t know/think it’s the m.2 though. (I don’t know much about computers anyway though so if I’m wrong please correct me)
(First build btw, and yes all the cables are plugged in)
Here’s my hardware:
AMD Ryzen 5 3600X 3.8 GHz 6-core processor
MSI MAG B550 TOMAHAWK ATX AM4
Samsung 970 Evo Plus 1 TB M.2 2280 NVME
EVGA GeForce RTX 3060 12 GB XC
Gigabyte P GM 750 W 80+ gold certified Fully modular ATX
Deepcool MATREXX 55 MESH ATX mid tower case
