H Hmb556 Distinguished Feb 20, 2014 89 2 18,635 Nov 16, 2016 #1 Building a new PC, can't get any power to the motherboard seemingly. The front panel lights come on but the debug LED on the motherboard doesn't come on, no fans spin in the case or in the PSU either. Any ideas?
Solution S S svan71 Nov 16, 2016 Check cpu install for bent pins,use 1 stick of ram, unplug all peripherals.
S svan71 Distinguished Dec 31, 2007 328 65 18,940 Nov 16, 2016 Solution #2 Check cpu install for bent pins,use 1 stick of ram, unplug all peripherals. Upvote 0 Downvote Solution
H Hmb556 Distinguished Feb 20, 2014 89 2 18,635 Nov 16, 2016 #3 I figured it out, had the power switch and front panel LED's switched. Thanks anyways! Upvote 0 Downvote
