Ryzen 5 2600 Cpu
Gigabyte B450M motherboard
G skill 2x4GB kit
Corsair 8GB
G skill 8GB
RX 480 8GB Power Color Gpu
Up Here Cpu cooler
EVGA 750W Psu
Kingston 120GB SSD
WD 7200 1TB HDD
G skill 2x4GB kit
Corsair 8GB
G skill 8GB
Up Here Cpu cooler
EVGA 750W Psu
Kingston 120GB SSD
WD 7200 1TB HDD
- Ryzen 5 2600 is new and seated properly
- The motherboard has been returned and I received a new one
- I had all my RAM sticks working for a total of 24GB DDR4 RAM, all set to a low speed, something like 2100 and they're all under 3 months old never been OC'd, and it has occurred to me that they are meant to run at 2400 Mhz
- My RX 480 8GB is installed but I have no idea which BIOS switch is which, last time I had it running with MSI Afterburner which revved the 3 fans. No Gpu sag and I cleaned the gold connectors on the card, it has a backplate installed on it
- Psu is used from my last build, also swapped it out for a Antec 650W, still no signal to monitor
- SSD and HDD, also my CMOS battery are new
- Up Here Cpu cooler has been installed with new thermal paste but the blue lights on it only flash for a second
- I did remove everything from my Zalman full ATX case into something smaller and less noisy. Everything spins and I can hear the Cpu thinking
- My first thought would be the CMOS battery, I did try resetting it with a screw, maybe I should have used a jumper or at least a paper clip.
- My monitor is new, an ASUS 32" 1080p with VGA and HDMI and I have a DP to HDMI adapter which was working fine until I swapped cases
