Okay, so im at a loss. I've been fiddling with my new setup for a while and i cant get get my pc to do 144 frames on destiny 2. I had no issues with my past card which was a 2080 ti, but when i upgraded to a 3080 ti it gets way too hot and underperforms. I bought a new case, fans, and set up a whole new water cooling loop for the entire setup and it is just not working. idk what to do, should i replace the water cooling block on the gpu back to its stock heatsink cooler and change my whole loop, or buy a new psu to see if its a power issue. ive changed the pump speed, tried underclocking the gpu, but to no avail... nothing. also cause the gpu runs so hot theres a ton of heat bubbles in the loop and everytime i clear them they keep coming back. pls help im so lost.
(Edit)
My specs are:
CPU: Ryzen 7 3700k
GPU: gigabyte 3080 ti 12 gb oc
MB: b550 tomahawk
Ram: 4 x 8gb ddr4 trident g.skill ram
PSU: Corsair RM750 Watt gold+
(Edit)
My specs are:
CPU: Ryzen 7 3700k
MB: b550 tomahawk
