My system is as follows:
I have the following problems:
I am thinking it is either a power supply problem or a motherboard problem.
Things I have tried:
The mouse would stay lighted at some times but now it won't stay lighted at all.
The slow boot up happens all the time.
The shutdown speed varies, with fast start up checked in power options it shuts down quickly, 2 or 3 seconds, but the start up time is still long at around 30 to 45 seconds.
When the fast start up is NOT checked, the computer will boot in around 30 to 35 seconds. This is for a SSD not a HDD. It will shutdown in 30 to 45 seconds.
BTW.....The system runs, stress tests and performs great, once it is booted up.
What settings, in windows 10 or in my bios, can I change to fix things. OR do I send the motherboard and power supply back to amazon and request replacements?
The reason I am thinking it might be a motherboard problem is because when I received the mother board, the MemOK!II switch was set to off and default is supposed to be set to on. This make me think some one has used and returned this motherboard already.
The reason I am thinking it might be the power supply is because the mouse will not stay lighted when the pc is shutdown even though the settings in Razer Synapse are set to stay on with monitor off.
What should I do?
thanks for helping
Chip
- slow startup and shutdown times
- Mouse and keyboard will no longer stay lighted when power is off
- Fresh install of windows 10 home when system was built.
- Checked bios settings and all were good.
- Changed the 30 delay for boot startup to 3 seconds, in windows 10 and in bios.
- Reinstall of windows 10 home.
- boot order is set to my ssd with windows 10.
- I have disabled high startup programs in task manager.
What should I do?
thanks for helping
Chip
