So i grappled with whether or not to setup my new system with water or go with great air cooling. I chose the latter after a lot of internal debate.
I put it all together last night, and lapped both my ultra 120 extreme and e6850 ... here's the setup:
e6850
ga-p35c-ds3r
8800gts 320
2gb crucial ballistix with d9 modules
ocz 700 watt gamestream powersupply
antec nine hundred case
I'm still warming the system up so i'm running 9x333. let me explain the cooling setup - i've got two 120 mm in the front of the case running full speed (rated 70 cfm each). I have a 120mm running six inches behind by top 120mm intake creating an 'air duct' right to the video card running full speed (rated 90cfm). the ultra120 extreme has a 120mm fan pushing air through the fins (70 cfm rated), there is an exhaust 120mm fan 2 inches from the back of the ultra120 extreme mounted to the case (110 cfm). the top of the case has a 200mm as an exhaut (rated 140cfm). the power supply is mounted on the bottom of the case with fan sucking air down and out.
The air flow is INCREDIBLE ... between the ultra120 extreme and the exhaust fan on the case i actually feel pressure that is hard to resist when i put my hand between the two.
thermal compound is arctic silver 5 ceramique.
So here's my issue. I'm using coretemp to measure. load with prime running maximum heat stress it's at 44C on one core and 47C on the other. This is at stock 9x333 and vdroop from 1.3 down to 1.264v when stressing. My idle temperatures hover between 28C on one core and 26C on the other core. I'm quite concerned.
Some reviews of ultra 120 extremes say that people have load temps in the mid 30s! did I do something wrong? perhaps I lapped unevenly? maybe those other people are measuring temp with speedfan instead of coretemp? maybe my system still needs to settle in? i have all these fans running on high and it's really loud - i knew this was going to be the case - but i thought i'd have cooler temps than these.
e6850
ga-p35c-ds3r
8800gts 320
