New to PCs and need help
SnappyRay
Hello! Thanks in advanced to all help. So I am new to PC gaming and I am in need of help. I don't know much about PCs when it comes to specs, however, I figured my laptop could run the game Wildstar. And alas, at ultra low, the framerate is still garbage. So, here are my specs. Thoughts on the specs or a cheap way to upgrade? Also, if this isn't enough, let me know and I will try to find more. Thanks!
Processor AMD A10-5750M APU with Radeon(tm) HD Graphics
Manufacturer AMD
Speed 2.5 GHz
Number of Cores 4
Video Card AMD Radeon HD 8650G
Manufacturer ATI
Chipset AMD Radeon HD 8650G
Dedicated Memory 736.1 MB
Total Memory 4.0 GB
Memory 7.4 GB
You can't upgrade the laptop, you need to buy a new one. Your system is above the minimum requirements for Wildstar but not close to the recommended specs.
Check for updated drivers from the laptop vendor and check the support site for the game for any suggestions.
