Hi guys, im new to building a pc so heres my question, im planning on buying a new pc from Cyberpower (i have to cant build one) so is this build ok? everything will work together?
I will be using it primarily for 3d modeling and rendering (Autocad and 3ds max) some graphic design, video editing and of course gaming.
So is this ok? or should i forget about and get a z97 with a 4970k
CARE1: Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation [+10]
CAS: CyberPowerPC X-Titan 100 MID-Tower Gaming Case w/ Side-Window Panel (White Color)
CD: LG 12X Internal Blu-ray Drive & DVDRW, 3D Playback Combo Drive (BLACK COLOR)
COOLANT: Standard Coolant
CPU: Intel® Core™ i7-5820K Six-Core 3.30GHz 15MB Intel Smart Cache LGA2011-V3
CS_FAN: Default case fans
FAN: Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Single Standard 120MM Fan)
HDD: 120GB Samsung 840 EVO Series SATA-III 6.0Gb/s SSD - 540MB/s Read & 410MB/s Write [+12] (Single Drive)
HDD2: 1TB Western Digital Caviar Blue SATA-III 6.0Gb/s 7200 RPM HDD [+68] (Single Drive)
HEADSET: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: AZZA Multimedia USB Gaming Keyboard
MEMORY: 16GB (4GBx4) DDR4/2400MHz Quad Channel Memory [+165] (GSKILL Ripjaws 4 [+49])
MOTHERBOARD: ASUS X99-A ATX W/ Intel GbE LAN, 4x Gen3 PCIe x16, 2x PCIe x1, 1x M.2, 8x SATA 6Gb/s [-170]
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
OS: None - FORMAT HARD DRIVE ONLY [-60]
OVERCLOCK: No Overclocking
POWERSUPPLY: 600 Watts - Corsair CX600M CX Series Modular 80 PLUS BRONZE Certified Active PFC Power Supply [+28]
VIDEO: NVIDIA GeForce GTX 970 4GB GDDR5 PCIe 3.0 x16 Video Card (Maxwell) [+248] (Single Card)
HEADSET: None
