Question Newer build freezing, and other issues ?
I've tried reinstalling windows and usual things like sfc /scannow but the issues persisted.
Any guesses on where I should start next? I assumed it was RAM so I tried downclocking, but no change there either. Unfortunately I don't have any other DDR5 memory to test with
PC will randomly freeze, and other odd behavior.
It freezes most often during gaming, but from what I can tell that's only because that's what I am most often using my PC for. It has also frozen from normal internet browsing and during school work, and other low load activities.
  • The freeze is a full lockup, occasionally hitching for a few seconds before full freeze. Only way out is a hard reboot.
  • Another odd quirk I've noticed is that at random times, with zero input from me, the display will randomly zoom out like some sort of multi-desktop feature, then zoom back in as if nothing happened. This can happen while gaming, and even when I'm not touching the keyboard or mouse watching a video.
  • And lastly It takes FOREVER to POST. I changed the initialization setting in the BIOS but It still takes roughly 2 full minutes to POST, as far as I can tell it is not cycling between different BIOS settings.
7700x stock settings (default auto boosting)
MSI MS-7D78 motherboard (BIOS 7D78v16)
32GB 6000mhz RAM (EXPO on & off)
Windows 11 22H2 OS Build 22621.2134
1300w EVGA Supernova PSU
6900-xt red devil
Mushkin Helix-L m.2 boot drive
Reliability History most often just records the "windows was not properly shut down" event after the freezes. But it has occasionally reports something else;
  1. "Windows stopped working" The computer has rebooted from a bugcheck. The bugcheck was: 0x00000133 (0x0000000000000000, 0x0000000000000501, 0x0000000000000500, 0xfffff8076831c340). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 3c8e27fb-58ed-4762-8b09-f6ddc968c98c.
  2. Shows up more than once: "Hardware error" Description
    A problem with your hardware caused Windows to stop working correctly.
    Problem signature
    Problem Event Name: LiveKernelEvent
    Code: a1000001
    Parameter 1: 1
    Parameter 2: 0
    Parameter 3: 0
    Parameter 4: 0
    OS version: 10_0_22621
    Service Pack: 0_0
    Product: 256_1
    OS Version: 10.0.22621.2.0.0.256.48
    Locale ID: 1033
    Extra information about the problem
    Bucket ID: LKD_0xA1000001_amdfendr!unknown_function
    Server information: 1183eb96-97cc-479e-a45e-d08952d4f9ea
TYIA
try bios version 7D78v17
was windows installed with this hardware components?
check temperatures
to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
Reset the BIOS by jumper clrCMOS or JBAT or similar (eventually you will have to set the boot priority correctly after that)
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean boot
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
check the hard drive for errors with its manufacturer´s tool
