Newly Built Computer Wont Power On
blopdak
17
I got all the parts for my new computer today, and started building it. When I tried to power t on for the first time, it booted, even posted, but about 30 seconds later it shut off. I began removing components to see if it was a problem with my Ram, video card, etc. It gotten to the point where I have nothing connected to the motherboard but the 24pin power connector, the 4pin power connector and the cpu fan. No difference.
Now, as of a few minutes ago, it wont even turn on for a few seconds. The power indicator on the motherboard is on before I pres the ower button, but when I press it, the computer turns on for a split second and then shuts off. The motherboards power light turns off at this point and then comes back on a split second after.
Is this a problem you've heard of? Is it fixable or do I have to do some returns?
It seems this could be either a DOA motherboard or DOA PSU. What do you think?
sorce7200
45
I have had the same prob on p4 630 Intel 915 mobo...exactly the
same prob...LoL. Believe me I know its no laughing matter.
First I felt sick, then scared, then angry...and before I tossed the
whole mess out...I decided to fix it if I could....
My prob turned out ot be a dust mote I missed on the flip side of
the mobo that had apparently been inadvertently sucked in by a
fan and had gotten lodged between the mobo and the case frame.
Removing the mobo assembly to the work bench and doing a
thorough clean job and magnifying glass inspection, then an
out-of-case build one component at a time usually works
wonders, and if not...then the prob is either mobo, cpu, psu,
or ram.
Here is something that might help tho:
http://www.fixingmycomputer.com/
good luck M8
blopdak
17
Well I just bombarded everything with compressed air... still not working. It's either the psu or motherboard because those are the only components hooked up now.
Is there anyway to tell which is broken? (I don't have another psu to test it with.)
blopdak
17
No, but I did feel sick, scared, and angry....
but seriously, anyone have a suggestion as to which componnt is likely the problem? If its the motherboard I have to take off the heatsink and cpu (pain in the arse with push pins) and if its the power supply i have to send it to the manufacture under warranty (slooooooooow). I don't want to end up doing both.
Similar threads
