I've recently built a system for a friend running:
Windows 11
ASUS PRIME X670-P
AMD Ryzen 7 7700X
Gigabyte AERO 4070 OC
Corsair Vengeance RGB 32GB (2x 16GB) DDR5 5600MHz C36
Cooler Master V850 SFX 850W
Samsung 1tb M.2
3 Fan AIO on the CPU
DOCP enabled
Latest BIOS installed
Periodically the system will do what im assuming is a "soft reboot" where it doesnt actually powercyle or anything (LEDS stay on no PSU click), the monitor will say simply go "DP Disconnected" (where the GPU disconnects i think) for a few seconds, then the windows logo with the spinning circle appears and shows the login screen as if the PC was restarted, all programs will start as per normal when logging in however anything that was open wont reopen.
I thought it could have been some kind of PSU issue as the system is running an SFX due to its form factor but the lack of it actually powercycling has me lost.
This error happens fairly often and Ive tried a few fixes online with nothing affecting it:
Windows 11
ASUS PRIME X670-P
AMD Ryzen 7 7700X
Samsung 1tb M.2
DOCP enabled
- Disabled DOCP (was previously enabled)
- Disabled Automatic Restart as per another forum post on here
- Checked temps while under medium load (Nothing was out of order, cpu 56, Gpu 39)
- Done a clean reinstall of GPU drivers with DDU
- Disabled G-Sync/Adaptive sync in the monitor OSD
