I have a problem. I have a LanParty NF4 Ultra Motherboard with 2 LAN Ports. One nForce Ethernet and another Marvel LAN (PCI). A while ago, I had a problem where the Ethernet port could not establish a connection. It would say acquiring address... then say "Disconnected". It would go on and off like that. (The Light on the LAN Port would flash on and and off as well. Also on the router (Linksys WRT54G), the light that I'm connected to would flash as well). So I installed the Marvel LAN drivers, and using this worked just fine. I switched out the router to no effect. So obviously it wasn't the router.
To fix the problem the first time, I just reformatted.
This problem hasn't happened again for almost a year. I reformatted like 2 weeks ago. Still no problem, then my computer went into Standby earlier yesterday(think one of my parents did it). After that, about 3 hours after use of the computer, I lose connection and it starts to do it again.
I just installed the Marvell LAN Drivers for now because I don't plan on reformatting so soon.
I've tried to research the problem, but I'm using the wrong set of keywords I assume and can't find anything about this problem. Another one of my friends had the same problem as me before. He got a new modem, and it worked fine after words, he was using nForce 4 as well.
So, does anyone know of this problem and knows how to fix it? Or can do a better job at researching the problem?
Or, even as a third option, is there a way to reinstall windows over top of the old windows without having to format? I doubt there is unless you made an OS partition, which I don't. I usually just backup my stuff onto one of my 250gb storage drives. But its such a pain to backup all my settings, then put them all back after reformat. *sigh*
Any help is greatly appreciated.
