Nivida card making my hard drive not get dected by bios/ pc?
Amoxy239
46
https://www.youtube.com/watch?v=TurdWEQ1MlE&feature=you...
here is the video hopefully it will explain more also i can not find drivers any where for this motherboard pretty sure whoever built this took it out of a pre built pc and just added parts. when i use the ati card everything works fine but the problem is its dying and is no longer reliable to use for gaming ( freezing sound looping etc..) so thats why i bought this card was the best i could find locally (small town..) and can not order a card online. but when i put in the 740 its like my hard drive jsut vanishes the bios /pc will not detect it at all unless i put it in native ide mode but then it wont boot just says disk error but if i do not have it in that mode it wont detect anything execpt for the cd drive
Also i thought it might have been the hard drive so i bought a new one today same problem..
Strange, what happens to the hdd if you put ATI back?
I'd check the hdd's data cable is inserted properly, on the motherboard (and hdd). Is it using the old style ide cable? Its been a long time since using those but from memory, i think it mattered which side of the ide ribbon with the red line painted on the edging was connected.
If you're using sata all of that wont matter, just make sure ide/sata is connected properly on the motherboard, maybe bumped when replacing the gpu, only thing that would make sense to me, a gpu simply shouldn't fault the hdd unless you had power running through the pc while changing parts which im sure you didn't do.
if i put the ATI back in ( like i did to make this post and to respond ) pc works fine like nothing at all ever hapend and i hade the power unpluged when changing the cards all cables are good hardrives good idk what to do caint find a answer any where and there sata drives so idk why it will only show up in the bios under ide when the nivida card is in but with the ati card in works normaly
CPU Name Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz
Threading 1 CPU - 2 Core - 4 Thread
Frequency 2925.56 MHz (22 * 132.98 MHz) - Uncore: 2127.7 MHz
Multiplier Current: 22 / Min: 9 / Max: 22
Architecture Clarkdale / C2-Step (32 nm)
Cpuid / Ext. 6.5.2 / 6.25
IA Extensions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
Caches L1D : 32 KB / L2 : 256 KB / L3 : 4096 KB
Caches Assoc. L1D : 8-way / L2 : 8-way / L3 : 16-way
Microcode Rev. 0x00000D
TDP / Vcore 73 Watts / 1.136 Volts
Type Retail (Original Frequency : 2933 MHz)
Motherboard
Model Gateway H57M01
Socket Socket 1156 LGA
North Bridge Intel Havendale/Clarkdale Host Bridge re
South Bridge Intel H57 rev 06
BIOS American Megatrends Inc. P01-B1 (03/23/2010)
Memory (RAM)
Total Size 4096 MB
Type Dual Channel (128 bit) DDR3-SDRAM
Frequency 664.9 MHz - Ratio 4:20
Timings 9-9-9-24-1 (tCAS-tRC-tRP-tRAS-tCR)
Slot #1 Module Samsung 2048 MB (DDR3-1337)
Slot #2 Module Samsung 2048 MB (DDR3-1337)
Graphic Card (GPU)
GPU #1 Type Intel(R) HD Graphics (Clarkdale) @ 733 MHz
GPU #1 Brand 0x1025 (0x0389)
VRAM #1 Type 1723 MB
DirectX 11.0
Storage (HDD/SSD)
Model #1 Western Digital WDC WD5000AACS-61M6B2
Capacity #1 500 GB
Display
Screen #1 Dell Computer DELL 1707FP (DEL4012)
Screen #1 Spec 17.1 inches (43.4 cm) / 1280 x 1024 pixels @ 56-76 Hz
Miscellaneous
Windows Version Microsoft Windows 8.1 (6.3) Professional 64-bit
Windows Subver. Build 9600
CPU-Z Version 1.74.0 (64 bit)
FSP Group FX 600 GLN 85%
Radeon HD 4870
All ready tried that D:
This is a long shot but not even sure if possible.
The 4870 uses 2x 6pin PCIe supplementary connectors at the back of the card, are you using a molex adapter for either of those? The idea is far fetched but is it possible your hdd is also connected to that same line via a y split?
The gt740 only uses 1 6pin, so my guess is the other 6pin where the hdd is connected to is no longer getting power/not earthed by having it not connected to the ATI 4780 thus not completing power circuit.
Check where your hdd is getting power from.
no adapter just the standard cords that came with the psu ill upload some picture here ina bit
well nothing seems to work guess im stuck using my old card to it compltley dies/ i can afford anew ati card first time buying nivida and its not going well at all :fou: , thanks for your help tho any ways and trying to find me a answer / replying :)
If you have a friend you can borrow a gpu from, try that sometime or try the 740 in another comp see if it actually works and not sending your machine bonkers.
Also look into updating your bios if you haven't done so.
If you have a flashing utility in the bios itself that would make things easier. Just copy the bios rom to a fat32 usb stick.
Your welcome too, if anything else comes to mind i'll let you know. This is also mind boggling for me, would love to know whats doing this. Seems all the links above i posted with other people having similar issues go through the same ringer as here and no definite answer as to why.
ya unfortunatly only 1 i know with a pc and there was only 1 update for this bios and it was back in liek 2006 or something lol old mb
na nothing at all worth updating never heard of it before but starting to think might not be compatible some how lol
ya me nether still caint figure it out tho
HI i updated my bios and then insted of gateway it know says acer do i went to the acer website and it auto detected my pc as a Aspire M5811 i updated to latest bios installed all drivers but still did not help
no I cant been more then 24 hours and it was the most powerful of the 3 they had so nothing to exchange it for even better new my ATIcard finally completely died on me know running on Intel integrated graphics and cant run anything know 25 fps on Cs go GG pc
