nividia control panel
fastkiller23
55
Throw nvidias control panel you can do color settings but I don't know what is the best combination of gamma,contrast.... for gaming, I play all kind of games but mainly bf4 please help.
It depends a lot on your monitor. All monitors are different in the way they display colors and contrast. You can purchase a pricey color calibration tool or just try adjusting settings on your own.
If you post your monitor make/model here, someone with the same monitor may be able to help you with custom color settings.
If you don't get a response, and you have Windows 7, there's a color calibration tool included that may get you close to what you're looking for.
1) Right click on the desktop background.
2) Choose 'Screen resolution' from the context menu.
3) Click 'Advanced settings'.
4) Click the 'Color Management' tab.
5) Click the 'Color Management' button.
6) Click the 'Calibrate Display' button and follow the instructions.
You won't be using control panel, but you'll still be able to modify the color and contrast settings through this tool.
