No audio/sound outside of Adobe Premiere?
Sep 23, 2018
I got a SuperMicro workstation with a X9DAi motherboard running windows 10 professional.
The problem is that my sound stopped working. I tried to uninstall all other drivers that handle audio, like for example Nvidias hdmi Hd audio (I think its called). But still no audio.
So I got a "Focusrite - Scarlett 2i2 2nd Gen" instead and the audio worked in Adobe premiere (perhaps in audition and after effects aswell) but nowhere else.
I think I reinstalled the workstation atleast once since then. But still no audio outside of adobe premiere. Premiere is using an Asio driver its seam like.
I had given up this and just keeped on editing in premiere. But now im switching over to Davinci Resolve and need to get the audio to work in there.
You would think that the audio problem with the built in realtek drivers should not matter anymore since Im using the external Focusrite as sound card. But maby its still causing the problem. What do you think is causing this problem? Im pretty out of Ideas!
//Joel
