no bottom or top fans
crazy25man
16
Newbie question here
I recently bought a masterbox lite 5 case which dont have top or bottom fan slot.(i use 3x120mm in front as intake and 1x120mm in back as exhaust)i use id cooling sf 12025 RGB as my fans
will it affect my component(video card,cpu,mobo,HDD,SSD,etc)temp drastically or just few degrees Celcius
Masterbox Lite 5: http://www.coolermaster.com/case/mid-tower/masterbox-lite-5/
SF 12025 RGB : http://www.idcooling.com/Product/detail/id/119/name/SF-12025-RGB
P.S. i use amd stock cooler(wraith stealth)
Only worry when temps are really too high,you can check like this,
download hwinfo64,
install and open it,
check "sensors-only",
click "run".
thsi tool seems to be as accurate on Ryzen as AMD's own tool,but you can for cpu temps use that as well.
Don't think you'll have to worry that much. There are reviews about that case so look at those if they do a temp test.Look at the reviews for the "MasterBox Lite 5 RGB" since coming at stock with that fan assembly.
download hwinfo64,
click "run".
