So, I have an HP Pavilion P7 1414 (AMD A8-5500 CPU 3.2GHz) which requires that I enable legacy mode in BIOS to get the computer to recognize a discrete GPU (mine is a Radeon 7750). It worked for a few years, but then started acting strangely. Once every few days I'd get no display when connected to the DVI port, so then I'd take the computer and hook it into the HDMI port with my TV (I have an older monitor that doesn't have an HDMI connection), then I'd have picture. Strangely after receiving picture using the HDMI I could then connect it to my monitor using the DVI cable and it'd work fine for another few days/weeks, then the same problem would occur.
Now it's not working with either. I don't have another computer to snap the GPU into to check if it's the card or else I'd do that. I've checked its connection and I've run a system diagnostic and the PCIe slot is working fine. So, is my card just fried?
Thanks.
Thanks.
