Question No display under any circumstances when using iGPU, however, dGPU works
DaddyK
21
I am using a MSI Z390 motherboard paired with a 9900K and a 30 series RTX GPU. This is one of the strangest thing I have ever seen in my many years of computer science.
I have a specific application where I need to use integrated graphics without a dGPU for an operating system. The only problem is integrated graphics refuse to work under ANY circumstances.
I receive absolutely no video output when using the motherboard’s I/O HDMI port. No BIOS, nothing, only "no signal/source." I have tried many different solutions and none of them worked. Even when removing the GPU, integrated graphics still do not work. POST is always successful (with or w/o GPU), everything works fine, no hardware issues at all other than the iGPU "not working" properly. The dGPU however, always works.
I do not think this is a BIOS setting related issue. I am in there pretty often and know each setting very well. The BIOS is MSI Click Bios 5.
Things I have tried:
- Enabling IGD/PEG multi monitor in BIOS which enables output from both iGPU and dGPU
- Enabling IGD only which sets iGPU as primary graphic boot device
- Removing the GPU while using both modes mentioned above
- Removing GPU and clearing CMOS
- Trying various HDMI cables
- Throughly inspecting the motherboard’s I/O ports and surrounding circuitry
- I even tried using different displays for the hell of it
- The BIOS is on the latest firmware
Bad port? Manufacturing issue? User issue? I’m at a lost and ready to chalk this as not happening. I think I’ll grab a VGA cable from work and test if it’s just a bad port. Thank you.
