Question No display when connected to graphics card, display works only when plugged into motherboard
Aug 3, 2021
Parts list:
Ryzen 3 2200G, MSI RX 580 8GB, 16GB G.SKILL RIPJAWS, MSI B450M PRO-M2, 550W PSU
When I plug my HDMI into my GPU, which previously worked, it shows no display (monitor turns on but says no signal), but when I plug it into my motherboard using integrated graphics it works. Note: I have cleared CMOS a million times and reset my PC
Lutfij
550W is the wattage of the PSU. What is the make and model of the unit? As for your motherboard, if you're able to get into BIOS, can you check and see what BIOS version you're on at the time of writing? How old is the PSU in your build?
Aug 3, 2021
Thermaltake Litepower Gen 2 550W Power Supply
BIOS Version/Date: American Megatrends Inc. 2.30, 2/11/2018
Bought on 10/03/19
