[SOLVED] No display
Omgitsjojo
16
Hello after taking a 15 hour road trip with my PC in it. I plugged in my PC and I would start up with all fans running keyboard and mouse lights on but no display to 2 different monitors and 2 different cables. I tried different PSU, gpu, ram sticks and tried different battery for motherboard. Nothing has worked. Time for new motherboard?
Clean your motherboard with isopropyl alcohol, clean ram slots, clean all ic pins using a toothbrush, if you are using intel-based PC then clean CPU pad. after that dry your motherboard with a hairdryer or something equivalent then test your motherboard.
