Question No ethernet connection ?
@louisfawk
Make and model for modem and router (or modem/router) if combined?
On your computer run "ipconfig /all" (without quotes) via the Command Prompt.
Copy and paste the full results here.
One possible problem is that both of the computer's network adapters (wired and wireless) are enabled. Only one network adapter should be enabled.
@louisfawk
Make and model for modem and router (or modem/router) if combined? i dont understnad this
Microsoft Windows [Version 10.0.22631.2861]
(c) Microsoft Corporation. All rights reserved.
C:\Windows\System32>
C:\Windows\System32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-KOM18E2
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : broadband
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : broadband
Description . . . . . . . . . . . : Intel(R) Ethernet Controller (3) I225-V
Physical Address. . . . . . . . . : E8-9C-25-C3-91-ED
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::26a:ab03:fb6b:34b5%9(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.63(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 15 April 2024 08:48:14 PM
Lease Expires . . . . . . . . . . : 23 May 2160 03:25:38 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 451451941
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2D-AE-62-67-74-97-79-FF-98-A5
DNS Servers . . . . . . . . . . . : fe80::d635:1dff:fe7c:f2db%9
8.8.8.8
8.8.4.4
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
broadband
Wireless LAN adapter WiFi:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : MediaTek Wi-Fi 6E MT7922 (RZ616) 160MHz Wireless LAN Card
Physical Address. . . . . . . . . : 74-97-79-FF-98-A5
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 76-97-79-FF-B8-85
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 76-97-79-FF-A8-95
Your ISP provides service to your residence.
The incoming cable connects to a modem which then connects to the router.
However the modem and router may be a combined device.
Most likely, when using Ethernet, the Ethernet cable is plugged into the router. (If using a wireless network adapter, the computer still connects via the router. But wirelessly via radio waves.
The devices installed in your residence should be identified with some manufacturer's name and a model number. The model number may be on the displayed on the device or provided on a lable.
What "ipconfig /all" indicates is that your computer is using a wired connection (Ethernet) and that the computer's wireless network adapter is disabled
The computer is currently being provided a DHCP IP address of 192.168.1.63 via a router with an IP address of 192.168.1.1 and Subnet mask of 255.255.255.0 Very normal and expected.
One immediate thing you can do is to disable IPv6. Disabling IPv6 as proven beneficial in many cases.
