X xtrips Distinguished Mar 17, 2008 34 0 18,530 May 18, 2020 #1 Hello. My PC has a Intel UHD Graphics 620 video card, it is connected to a Samsung UHD HDR screen, via a tested with HDR HDMI cable. Nevertheless Windows 10 says the screen is not HDR compatible, only SDR. What can I do?
Solution drivinfast247 May 18, 2020 You may need to turn on HDR support for the particular input port you're using on the TV.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,106 912 120,140 May 18, 2020 #2 Exact model of Samsung monitor? Upvote 0 Downvote
X xtrips Distinguished Mar 17, 2008 34 0 18,530 May 18, 2020 #3 Phillip Corcoran said: Exact model of Samsung monitor? Click to expand... Hi. Not monitor, TV. 43RU7100 Upvote 0 Downvote
drivinfast247 Glorious May 29, 2018 7,843 1,643 47,940 May 18, 2020 Solution #4 You may need to turn on HDR support for the particular input port you're using on the TV. Upvote 0 Downvote Solution
