No Icon of Smart Gesture on asus, I cant Fix it! help pls.
Fermin_1
Commendable
Jun 5, 2016
I tried to unistall, install my smart gesture, and also try to repair, but still it won't work, and the icon on the down right side of my screen has no touchpad icon, i don't know what to do anymore? Do i need to reset my laptop? i'm using asus x555LN and also updated to windows 10. Please help me, Thank you!
Hi,
Please do try these troubleshooting steps that may help.
- First is to try to customize the notification bar at the bottom right hand corner.
- Try this steps from this link: http://www.tenforums.com/tutorials/5313-notification-area-icons-hide-show-windows-10-a.html
- If it doesn't work since you've already tried to uninstall/reinstall the driver is to perform System Restore.
- Here's how to run System Restore: http://windows.microsoft.com/en-ph/windows-10/windows-10-recovery-options
- And if all these will not work, last option would be to reinstall Windows.
