[SOLVED] No Monitor Display after Restarting PC
My PC was working fine until I restarted my PC. After restarting, there was no Display. I can hear the fans running and see the GPU lights. Only the display. So I tried one solution: reseating the memory sticks (RAM). After that, the display came back and everything is running smoothly. Until I restarted my PC again, and then it happened again. So I reseated the RAM again. Now it's okay. What do you think is causing this problem? I am afraid that the next time I turn off/restart my PC, the problem will return again and again and I have no choice but to face the hassle of opening my case and reseating the RAM. Please help me.
Specs:
Windows 10 Pro
i7-7700
Asus Prime B250M-D
16GB RAM (2x8GB)
Inno3D RTX 2060 Super 8GB
Thermaltake 650W PSU
Asus VP249QGR Monitor
Thermaltake is the brand of the PSU while 650W is the wattage, it doesn't state the series the PSU is from and it's quality. Please include that information as well as the age of the PSU. You might want to see if the issue crops up with only you powering your display off the iGPU(with the discrete out of the system).
