Specs:
Cpu: Ryzen 5 3600xt
Cpu cooler: Coolermaster Ml120e
Mobo: Gigabyte Aorus B450I Pro Wifi
Ram: 2x16gb DDR4-3200 T-Force
GPU: Asus Strix RTX 2060 Super
Case: Evolv Shift 2
System will not give a display. So far I've swapped the GPU, Ram, and PSU, and it has the same symptoms:
-CPU had some bent pins, bent them back
-Cleared CMOS, nothing happens
-When the 8pin CPU connector is unplugged, it shows the same symptoms
-Motherboard RGB LEDs are on
I believe it's either the CPU or Mobo itself, anyone know the true answer?
Cpu: Ryzen 5 3600xt
Case: Evolv Shift 2
- Case fans are spinning, GPU fans are maxed out
- CPU cooler is not working, cannot feel pump vibrating
