No POST lound fan on CPU change HP/Compaq Elite 8100 SFF correction i3-550 not 2120
Tony_63
19
for hp/compaq elite 8100 sff i swapped out an i3 550 @3.2 GHZ for a i5 650 (which is a specified upgrade) using same original & fairly impressive heat sink and have had no post, no screen and loud fan after 45 secs. No beeps either. I tried with NO ram just to check m/bd and had correct 5 beeps -puzzled. m/ bd is mS 7757 Ver 1.0. Thanks Regards Tony
hi amended my post because original cpu is an i3 550 rather than as I incorrectly stated an i 3 2120. thanks for advice!
hi my original post INCORRECTLY stated that an i3 2120 was the original installed cpu -it was nt it was an i3 -550 which worked fine. I believe i3 550 cpu was the original specification as have the HP Elite 8100's from IT recycler. I then installed the i5 650
AND
"using same original & fairly impressive heat sink and have had no post, no screen and loud fan after 45 secs. No beeps either. I then tried with NO ram/hdd just to check m/bd was OK and had the correct no of beeps 5 no. -puzzled"
