No power, nothing labeled on motherboard, any ideas?
Millgo47
77
I just installed a new power supply CX750
I thought I rehooked everything back the way I had it but when I hit the power switch I get nothing.
My tower is HAF 932 full tower.
My mother board is HP IPISB-CH2 (Chicago)
Not sure if the pictures help.
http://s1262.photobucket.com/user/Millgo/library/
Thanks
Hi. You sent pictures of everything but the important stuff. Make sure the 24 pin ATX connector is snuggly plugged in an clipped. Same with the 8 Pin CPU connection. Most times that is actually 2 four pin connectors and can be a bit difficult to get plugged in. They are identified by yellow and black wires. I think the PCIe connectors are too, but they are marked as PCIe.
I uploaded the pictures you asked all the wiring seems tight
Sorry. I had to enlarge them. The connections look good. AS for the front panel stuff, you shouldn't have had to unplug that for a PSU changeout, so shouldn't be an issue. They looked alright from what I could see. Make sure the switch on the back of the PSU is on.
Thanks you were right, it was the 8 Pin CPU connection it was just a bit loose and not fully clipped, I thought I triple checked, apparently not haha, Thanks for your help; appreciate it.
Yeah, those things are difficult. The reason I made that last suggestion is because I have been working inside one then went to start it and nothing. I checked everything, but couldn't find anything out of order. I just happened to check the switch on the back of the PSU and I had inadvertantly shut it off while moving the computer.
