I believe I have everything connected properly. I am using almost the exact same setup I did on my first build other than the PSU, GPU.
Specs:
Case: NZXT Phantom 410
CPU: i5 3570k
Heatsink: Hyper 212 EVO
MoBo: ASRock Z77 Extreme4
RAM: Corsair Vengeance Low Profile 8GB 1600
GPU: EVGA GTX 680
HDD: Seagate Barracuda 1TB 7200 RPM 64MB SATA 6.0
PSU: Seasonic SS-620GM (first build used a Seasonic X-Series 850W and worked like a charm)
Optical: ASUS DRW 24x DVD-Burner
Everything is identical compared to my first build other than the PSU. I have never encountered a problem with not being able to power up a PC so how does one determine if it is the PSU that is dead or faulty or can something else cause the system not to power up.
Specs:
CPU: i5 3570k
GPU: EVGA GTX 680
