No screen found problem [NEW BUILT PC] [PAYING FOR FULL HELP]
Sycooc
8
So i just finished building my gaming pc.
After finish i powered it and every single fan and led worked so i connected the hdmi to my monitor that i just bought and it said that theres nothing plugged in.
Can you guys help me please? Ive tried 2 different monitors and 3 different hdmi cables!!!
Please help me :L
gpu - Amd r9 280x
mobo - amd a3+ gbt ga 990xa-ud3
case - corsair carbide series spec 01 mid tower
cpu- amd fx6300 6 core
psu - corsair builder series cx 600 watt atx eps 80 plus bronze
hhd- seagate str10000dm003 barracuda 1tb
ram - 8gb team elite plus black ddr3 pc3 14900 duel channel kit
thanks for helping
yes i have them connected to the motherboard and yes hdmi cable plugged into the video card with the monitor turned on
It says check signal cable
i have no other graphic cards, the screen wont even work
But its impossible for me to get someones graphics card 🙁
Im going to disconnect all the cables and redo them, ill tell u what happens
Ok. Take into account also that messing too much with the components might damage them.
An option would be buying a case speaker http://images17.newegg.com/is/image/newegg/12-201-032-TS?$S300W$ (it's cheap), connecting it to the board and checking if any beeps when starting the board without RAMs.
Are you able to boot without the R9 280X plugged in? I've read another post where a user isn't getting any display with the R9 280X.. makes me think it's a common problem...
If you can, boot without the graphics card in, load into the BIOS and change the graphics configuration to 'PEG' or PCI-e Graphics.
The FX 6300 has no built in graphics. So he must use a card.
I would try using a differant HDMI cable your could be bad then try a differant connection from their, VGA , DVI
Onboard (motherboard) graphics? lol, the last time I saw an onboard mobo graphics was my old Presario SR1949UK haha
How do you suppose he boots into BIOS and makes any changes without having a display LOL!!!!!!!!!
