I have NO signs what so ever to the system, no lights, no beeps nothing.
The following is the steps I've tried.
Note: I just moved back from overseas, the computer was in storage for many months, but was working fine for the last 5 months.
System configuration when it stopped working (wife was using it when it shut off twice with a message she did not record, third time it wouldn't turn on at all.
Memory
1 x G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C9D-16GXM
Motherboard
1 x GIGABYTE GA-Z68XP-UD4 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU
1 x Intel Core i7-2700K Sandy Bridge Quad-Core 3.5GHz (3.9GHz Turbo) LGA 1155 95W Desktop Processor Intel HD Graphics ...
CPU Cooler
1 x COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler Compatible with Intel 1366/1155/775 and AMD AM3/AM2+/AM2
POWER SUPPLY
1 x Cooler Master Silent Pro M - 850W Power Supply with 80 PLUS Bronze Certification and Semi-Modular Cables
VIDEO Card
1 x EVGA SuperClocked 01G-P3-1461-KR GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
PRIMARY HARD DRIVE (SOLID STATE DRIVE)
1 x OCZ Vertex 3 VTX3-25SAT3-90G 2.5" 90GB SATA III MLC Internal Solid State Drive (SSD)
CASE
1 x Cooler Master HAF 932 Advanced - High Air Flow Full Tower Computer Case with USB 3.0 and All-Black Interior
DVD/BLU RAy
1 x ASUS Black Blu-ray Burner SATA BW-12B1ST/BLK/G/AS
Computer showed NO sign of life at all, no lights no beeps no fan at the power supply.
When It stopped working, the power supply was under warranty so I simply sent it back (was in a hurry and this seemed the most logical issue). They sent me a NEW power supply (in shrink wrap, looks like it had never been used and is 1000W so same model now but more power. Plugged it in STILL nothing.
Pulled all the power connections and put a paperclip to pins 15 and 16, flip the switch and the power supply comes on. Plug it back in, nothing.
Change the CMOS battery, Nothing.
Pull the power switch leads, put a paper clip across them, flip the switch, nothing.
Thinking then that only leaves the motherboard, I purchase this. motherboard
1 x ASRock Z77 Extreme3 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Fully install it and all the components, nothing.
pull the memory, nothing.
pull all the drive SATA cables, nothing.
Thoughts?
Memory
Motherboard
CPU
CPU Cooler
POWER SUPPLY
VIDEO Card
CASE
DVD/BLU RAy
Thoughts?
