No Signal from PC while using HDMI connection while attempting to game
malopezsr
When attempting to play any of the games I have purchased for my PC, after a few minutes my screen goes blank. I use a T.V. as a monitor and it reads, "NO SIGNAL" it tells me to check connection. I do this, i unplug everything and then replug, but t does nothing. I use an HDMI cable from PC to Monitor. If I restart computer its fixed, but the moment i attempt to play any game, it happens again. The computer is strong enough to handle any minimum specs required, and can function while using 3 AutoCad programs at once. Is there a setting on computer or in game that I can change to prevent this from happening? Please help
Make sure your games are set to the resolution and refresh rate your TV can use. It may also be the video card crashing. Test it with another monitor to make sure it can run fine in general.
you were right:
"The Samsung SmartTV SDK Emulator does not support 1920x1080." had to drop it to 1280x720
Thank you
