Question No signal from Rx 470 but iGPU works okay?
DarkDimensionZ
22
CPU: i3 2100
Motherboard: samsung h61s1
Ram: 2x4 ddr3 1000 something mhz
SSD/HDD: 3 seagate 2 250 and 320
GPU: rx 470 4gb sapphite nitro 4gb oc
PSU: rakk 400 watts
OS: windows 10 2004
my pc is transported a long way to our province and when I turn on the pc no signal from gpu, but when I unplug and plug on motherboard vga it has signal. I am using a non true rated psu and 1 sata to 8 pin I suggest the 1 sata to 8 pin is broken? or graphics card? the motherboard pcie x16 is good as I say because I plugged my g210 on my pcie and installed drivers fine pls i need answers
A.should I replace sata to 8 pin with SATA Y to 8 pin?
B.should I replace power supply with true rated bronze 80+?
C.what do u suggest better?
