I got a new Gigabyte GTX 1070 G1 a few days ago and I am unable to get any signal from any of the outputs.
I replaced my old GTX 780 with the GTX 1070.
I have tried all the things listed below but still no joy!! the onboard graphics works from the mobo and so does the GTX 780 if I pop it back in but the GTX 1070 does not want to work!
When the card is installed it lights up and fans run but absolutely no signal.
Do you think I have a duff card!? 🙁
Any help you can suggest is very greatly appreciated. Thank you for reading my post
I have tried -
All outputs - DVi - HDMI - DP
I tried a different monitor
I have removed all old drivers with DDU and started fresh
I have disabled on board graphics and tires install of 1070
I have checked all Bios settings to make sure it is selecting the PCIe
I have reset Bios (reset button and jumper)
Bios is up to date
I tried other PCIe slot
Windows 10 is all up to date
I have tried a different power supply
I have gone over system and checked all items are fitted correctly and working
My system spec is
ROG Maximus V Gene
i7 2600k 4.4ghz
Corsair RM 850 PSU
16gb Corsair Vengeance
Samsung SSD
Windows 10
I have tried -
Bios is up to date
My system spec is
ROG Maximus V Gene
i7 2600k 4.4ghz
Corsair RM 850 PSU
Samsung SSD
Windows 10
